Old 02-05-2013, 09:08 AM   #1
spongebob
This is the same behaviour as in the old mans Jaguar Mk2
Slowing down from highway causes the oil lamp to light up for a while, this is due to worn engine bearings and an old pump. In case of a Boxster it is most likely the sender, but before you know I would not recommend to drive a single second with a flashing oil pressure light, does not take long for a total disaster to happen if it is actually bad
spongebob is offline   Reply With Quote
