Old 02-01-2013, 08:06 PM   #18
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by rondocap View Post
I did try tonight to "bed them". I read somewhere else though to brake fairly hard from 60mph, and I did that a few times. That article said to brake moderately from 40mph. I hope I didn't mess anything up!
After my attempt, squeal seemed to get better for a few minutes but then came back as bad as before. Maybe I just need a couple more good stops, I'll try the moderate from 40 to 5mph.
You didn't mess things up. If you went to 60, hit them hard down to 5mph and did it again 2 more times you should have started to smell the pads. You did it right, it wouldn't be the reason for low speed squealing. You just need to use the right lube and put enough on. You'll see once you figure this out you be an expert at it, I know I had to learn the hard way too.
