Old 02-01-2013, 07:51 PM   #15
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by rondocap View Post
I just came back from a drive, and did a few hard brakes to see if it would help - but nope, a lot of noise still under 15mph.
Basically, is it normal and will it go away once the pads form to the rotor, or is this something that needs to be done again with some anti squeal or something?
You should not be having this problem. Balo's rock and Mintex work just fine...though dusty compare to Akebono. I'll get the name of the brake lube I use, it works fine. I used some stuff once that was supposedly the best and it squealed at stop lights (very embarrassing). I'll get both brands in the morning and update you.
