Thread: Peel out?
Old 12-19-2005, 11:19 AM   #10
olly986
Guest
Posts: n/a
porscheguy, i had a 97 tip 2.5L and even if i never smoked rubbers (i never really tried) in first gear the car would go faster than what you are describing. it would usually scream and change gear itself to protect the tip, something that it does in 2nd and 3rd gear actually and i guess 4th too!
the automatic position of a tip start in second usually because the torque is too high in 1st, could you have some kind of problem with your gear changes, in which case i would not mess around trying to peel off as you say and find my gearbox on the ground or through my boot!
find someone with a similar tip car or get it check by someone that knows about tiptronic.
