Old 01-24-2013, 06:30 PM   #19
Gilles
Currently 3 of the 20 engines I have in my queue come from Caumans that died on the track. All were the same issue.
The G forces are NOT the root of the problem.
Jake,
Do you believe that some of these engine could be failing due to connecting rod bolts that stretch..? Or connecting rod bearings that fail due to poor lubrication?
a mix of these two, or something else?
Hopefully you won't mind sharing your comments, thank you.
Gilles is offline   Reply With Quote
