Old 01-19-2013, 12:13 AM   #7
Steve Tinker
Steve Tinker's Avatar
Theres a good chance tht you voltage regulator (mounted inside your alternator) is breaking down under load and perhaps your battery charge rate is suffering too.
A simple test (with a multimeter) is to check your battery static voltage - it should be ~12.6v cold - then check the charge voltage @ +/- 1,500 rpm which should be 13.5 - 14.5 v.
This is just a general test because the alternator could be breaking down under load, in which case you need to conduct load tester to your alternator......
2001 MV Agusta F4.
