Old 01-18-2013, 11:24 AM   #9
thom4782
thom4782's Avatar
It does sound as if the micro-switch has failed. Once the car doesn't sense correctly the actual position of the window all sorts of weird symptoms occur. One question: does the window behave in a similar way on the passenger side? The reason for the question is to narrow down which micro-switch failed. Each door has its own set.
