Old 01-18-2013, 11:22 AM   #3
BYprodriver
BYprodriver's Avatar
What's the easiest way to change the power-steering fluid? Do you drain it from somewhere or pull it out?
Easy way is to use a Turkey bastard to suck out what you can & top off with new. Repeat as needed. If you want to go deeper the reservoir detaches from the pump body but it's a pain to remove & replace.
