Old 01-15-2013, 05:47 PM   #13
Eric G
Theoretical propagandist
Eric G's Avatar
Does that dannmar have to b bolted down permanently?
You can use Hilti Quickbolt anchors that will allow you to bolt it down and then remove the nuts (leaving the bolt in place in the concrete) and remove the whole unit. Alternate idea would be to use drop in anchors (HDI's) wherein you leave the threaded unit in the concrete and use the bolt from the top down, this would leave you with a flat surface on your floor.
