Thread: Oil leak
Old 01-14-2013, 10:02 PM   #13
shadrach74
Originally Posted by afpa View Post
Good lord... add a new clutch to the damage. Mechanic did a nose to tail check: suspension, exhaust, tranny, wheel bearings, etc...all good. Asked about the IMS and they said it's solid.
So... I've had her for less than a month.
Tires: $700
4 wheel alignment: $110
RMS, clutch, leak at valve cover: $3200
I've officially lost the glow from buying my first Porsche.
$3200 seems steep... The parts cost if you pay retail for a stock clutch/RMS should run <$650 unless you're replacing the DM flywheel as well. What exactly are you getting for the other $2550? That's 25.5hrs or more at most indies. The clutch/rms should only take half of that.
shadrach74 is offline   Reply With Quote
