Originally Posted by Parrot356
I actually tried to install this one on my '01S yesterday (I bought it a couple of months ago and finally got around to trying to install yesterday). I couldn't get it to work so I gave up and reinstalled the stock shifter (with the new bushings). The center section of the new shifter was contacting the shifter mounting base and the pivot arm was about 1/4" longer than the stock shifter which meant the cables were too short to allow for full engagement at either end of the shift pattern. No matter how I adjusted things I either gave up reverse or gave up 5 and 6th.
I am thinking I either got a bad shifter or I am doing something wrong. There are too many other people that say they have these units and love them....
I need to contact the seller today and see if something can be done...
I got one from Topspeed but it looks like the one above. Install was straightforward but I couldnt get it to work right. Too tight or shift problems etc. I could not use the shift lock tool as it wouldnt fit this. So, gave up and reinstalled the original shifter but used the metal holder with the plastic bushings. Now I'm happy.
The issues I faced made wonder if there was a transmission issue. But now i know that is not the case. Either I got the wrong part or I was doing something wrong in the install process. Either way no more wasting time.
