Originally Posted by jsceash
Well I broke down and did it. Sitting on the floor of my garage is a 3.2 engine. new front bumper cover, center inside and outside trim and radiator duct. center radiator hoses, Front S brake caliper rotors pads, Carrera air ducts. On order still deep sump X51 baffle and L&N IMS kit. I have to be ready and tested by March 14.
My biggest question is the ECU Will the 2.7 ECU able to be programmed to handle the 3.2 or will I need to find a new ECU. I already check all the plugs look the same.
If this is for a 2003 & the new engine is Vario-Cam + you shouldn't have to touch the DME ECU & shouldn't touch it unlees after the 3.2 is running well you want to flash a higher performance program.
