Originally Posted by BYprodriver
See if the rear O2 sensors are long enough to work in the front, they should. If so you may want to get new rears & install in the front. You may get a CEL for slow heating of the O2's so keep in mind to minimize that.
Thanks pro. I usually do my own work but things are so hectic with work lately that I just have to pay someone else at this point. If the rear o2 sensors are longer then that seems like an easy fix. What's the worry over the heater? Would I be better served to try something different? My mechanic was able to make it work with the 90 degree max speed mini cat so the distance is probably about 2".
