Old 01-09-2013, 08:50 PM   #10
Topless
Track rat
Topless's Avatar
thstone,
Once you have the airbag sensor harness properly connected to the stock seatbelt connector you can reset the airbag with durametric and the lamp will stay out. The problem is the harness can be inserted several ways and only the original connection alignment will work. I marked mine clearly with a felt marker so I could disconnect and reconnect without getting stuck in airbag purgatory. We often take out our pass seats for timed runs these days. No airbag light.
