Old 01-08-2013, 03:42 PM   #1
supertarmac
Prolonging Window Regulator Life? Getting rid of grinding noise?
Hey Guys,
Good evening to you all.
This morning my passenger side window started to make the grinding noise when going up and down that indicates the window regulator that is about to go bad. It works fine at the moment, but started with the noise.
I've done a search and found out that for some of you the when windows first starts to make the noise it starts to get stuck in a matter of days and for some others it continues to work fine for months.
I wanted to know if there is some component I could grease or lubricate to prolong the life of the regulator and maybe get rid of the noise? Where I live Porsche parts a very expensive and might take more than a month to get the part.
And also, if this has happened to your car, how long did it last between when it started with the noise and when it stopped working at all?
Thank you so much in advanced
supertarmac is offline   Reply With Quote
