Originally Posted by RandallNeighbour
John, you know, it might just be your ignition switch going out, but if you've replaced this recently it's probably the heater core.
I replaced the ignition switch about 6 months ago so hopefully that's not the problem. I did find there is a heat actuation relay in the bank so I'm going to replace that tonight and see if it does anything. Otherwise, like you say, I'm afraid it's the core.
