i know the power is in the fuse box panel next to your foot. it is #6 and should be 12v because it powers my subwoofer. if you wanted to wire it...there has to be a pigtail or some sort of insert to plug the seats in. i know the member Stryke has heated seats ask him where it plugs in. then you would have to stick a fuse into the panel (check the rating in the little fuse booklet thingy)and ground it cause in the panel it only has the + available. then run a test wire to the seat plug and maybe ground the seat. put some switch under the seat. i'd also run low rating fuse while testing...maybe a 7.5. it sounds like a hour to test hack it and 2 hours to make it look slick. i'd do it but i live in houston and from march to november it's.....well... Hot.
let me know if it works.
