if the center console displays the outside temperature your computer is on and i think you can add a couple of switches to scrolling thru the options. the heated seat relay is wired into the fuse box on #6 regardless. i use it to power a subwoofer. if your seats have coils or something under the seats already i would assuming you could just wire it up, maybe stryke can let you know what the heater element looks like. cruise i'm sure can be added. if the dealer added all those in i'd guess you'd probably fork out at least 5k assumming that you don't need new seats. heck a front headlight cover is like 450. good luck
