Old 01-06-2013, 08:24 PM   #1
AKnowles
AKnowles's Avatar
Fingernails required to open frunk
My frunk will not pop open. It requires that I reach under one of the corners by the light to open it enough to disengage the latch and open the frunk. I doubt this is normal as closing it stops at just the point you expect it to pop on opening then requires a firm push to close.
Is there a spring, rubber bumper, or other item that needs adjusting to make the frunk pop open that 1/2 inch or so after pulling the release cable? FWIW, this is on a 1999 Boxster.
PS: I did quite a bit of searching but almost everything I found was about opening the frunk with a dead battery.
