You have to "enable" AUX on the CDR220. I can't confirm if these steps are exactly right, as I don't remember what site I checked (I was frustrated and sitting in my car looking at sites on my phone), but this sounds about right
You just need to enable the "AUX input mode" on the CDR 220. To do this, press the TP button for about 10 seconds. This will take you to the "BECKER 1" menu. Turn the tuning dial until you see the "AUX OFF"selection. Then press one of the soft buttons with an arrow above it to toggle the AUX mode to ON.
Now, not sure if you will be able to "select" it until you have a cable. But when you do get the cable, should be able to select it as an input with no issue, just have to press the S button.
