Old 01-06-2013, 10:10 AM   #10
Jake Raby
Engine Surgeon
The IMS Solution removes 13 wear components from a single row IMSB equipped engine. These are replaced with a bearing flange/ support and a bushing. Clean, pressurized oil becomes the new "support surface".
This is not new to the M96 engine; in fact the other end (oil pump end) of the IMS is supported with this EXACT same technology with pressurized oil from the oil pump directly feeding it. This pressure and volume is exacting what we deliver to the IMS Solution through the spin on oil filter adaptor.
The "other end" of the IMS never wears in these engines, not even if the engine suffers from oil starvation on the track.
As always Less = More.
US Patent 8,992,089 &
US Patent 9,416,697
