				A very easy project...
			I replaced my broken hinge in under 45 minutes, including disassembly, cleanup and reassembling the interior.
I thought it way too much work to remove the entire console, so I removed my storage unit and the carpet on the rear bulkhead to put in the u-shaped inserts.
The hinge plate fits only one way and it already had 4mm holes, so I used it as the drilling template.
I already owned a rivet gun, so all I needed to buy was a 4mm drill bit from Lowe's.
				Six speed 2000 Boxster S
