Old 12-14-2005, 06:23 AM   #1
JDM
Sway bar links/suspension noise
I have a noise coming from the rear and the front both sides of the car which seems to get worse as the car heats up after driving a while - it's most noticeable at low speeds and when I hit a road break or a speed bump. I have made my research to PCA.ORG and according to similar cases mentioned in the site
" The number one cause of suspension noise are bad sway bar links "
Now my questions are as follows :
a ) if has anyone until now have a similar noise problem and solve it after the replacement of the sway bar links or another suspension part .
b) Should i take the opportunity to change something else also now on the suspension system except of the sway bar links.
thanks.
JDM
JDM is offline   Reply With Quote
