Hammer - you seem to be having two issues, unless the first is somehow causing the second. When it does crank and you say it stalls does it seem like it is getting a full crank? If not I would say the issues are not related. I know my clutch switch is not good but like Dorag says once I get it to work it starts up ok.
I will note that before I figured out how to get the clutch switch to work sometimes I would release the pressure on the clutch ever so little and car would begin to start and then stall out.
