			Hi Rob,
Welcome, you car looks lovely. As flavor said, ref the brakes, they are huge solid calipers and tend to go through pads and discs on a frequent basis, and always benefit from a brake fluid flush to sharpen them up. This usually gets missed.
I also upgraded my rubber brake lines to stainless too, but to be honest, not a massive difference!
You get used to them...
Ref the whine, the flat 6 engine sounds like no other car and it could be that it just sounds different to the 928 engine, especially as its right behind you. The quickest way to check this is listen to another one!
True, it could be a bearing but don't rush in just yet.
Do you have an indie or Porsche dealer nearby? (The closest to me in S****************horpe is Sheffield!) - Listening to another Boxster may help.
Good luck PAL
				It will all end in tears I tell you.......
