Old 01-04-2013, 06:49 AM   #1
JFP in PA
Originally Posted by linklaw View Post
I got an email back in December from Flat 6 (Jake Raby's Company) that said they developed a new, permanent fix for the IMS bearing. They apparently eliminate the roller bearing and replace it with a conventional, oil fed bearing. I didn't see any info on pricing or on whether the replacement can be made without engine disassembly. They call it the Ultimate Solution, I think.
To my knowledge, this new system will at least initially only be available as a install at Jake’s shop in GA, and not as a “field retrofit”.
