Old 01-03-2013, 02:33 PM   #4
Black Stallion
Black Stallion's Avatar
No check engine light. The engine runs absolutely perfectly. It's almost as if the gas pedal isn't working. In neutral, I can put the pedal to the floor, and it will go to about 1600 - 1800 rpm. The battery was disconnected during the entire console delete process. I DID re-connect and disconnect the battery several times during a window regulator replacement at the same time. Never removed the seats.
Black Stallion is offline   Reply With Quote
