Old 01-02-2013, 06:52 PM   #1
JFP in PA
If you suspect a coolant leak, warm the engine and then run a proper leak down test on each cylinder. If you have a head or head gasket issue, it will show up in the numbers. I would also follow san rensho's lead and consider adding UV dye to the cooling system, it will leave a trace where ever the coolant is going.
