Old 01-02-2013, 01:33 PM   #2
Gilles
Originally Posted by jacabean View Post
you should change it yourself if you can and save the $$$$$ . if thats not the problem then at least you got it done .
+1.. (save the $$$$)
If you already replaced the auxiliary air pump you are familiar with the neighborhood, is not to difficult you just need to be patient, try to get the tool for the clamp hose it turned out to be a good investment for me.
If I remember correctly, I bought an AOS from Rector Porsche for less than $200 and it should take you a couple of hours and you will save a bunch...
Good luck
