Most likely simply need a wheel balance (vibration) and an alignment (pulling) but the other possibility is wheel bearing (both). Raise the wheel off the deck and try to move it in and out. You should not feel any movement. Then push the brake pads back away from the disc and spin the wheel. Light scraping will be the brakes but there should be no rumbling or groaning. Movement and or noise means wheel bearings.
