Old 12-28-2012, 05:59 AM   #1
paulv
Bala,
You're almost there. It is imperative that both valves in the cylinder under test are closed -- so TDC or BDC. It is better to test with TDC but some people have safety concerns and use BDC. I always go with TDC and leave the car out of gear (or in park). haven't had the need to do this with my Box, but helped out a couple of friends with their junk cars.
Here are the items required for your testing:
Throttle body open -- allows for hearing leaks from a bad intake valve(s).
Exhaust system (obviously open) -- allows for hearing leaks from a bad exhaust valve(s).
Remove oil dipstick -- allows for hearing leaks into the crankcase from blowby caused by bad rings.
Coolant fill cap -- allows for seeing bubbles in the coolant caused from cracked head/headgasket/etc.
Regards,
paul...
paulv is offline   Reply With Quote
