Old 12-28-2012, 04:38 AM   #1
Bala
Originally Posted by Steve Tinker View Post
Doing the tests with a cold engine will not prove a thing - an engine @ normal operating temps will always give the most accurate results.
After saying that, at 92,000 miles I think the results are not perfect but not too far off the optimum......
Theres a lot of owners out there would love those leak down resulta at that mileage.
Was curious what the difference would be.
Cylinder Leak-Hot Leak-Cold
1 3% 7%
2 5% 6%
3 2% 5% (this I happened to leave for an hour and it was @ 10%)
4 1% 4%
5 7% 5%
6 1% 6%
Something tells me I may not be doing this right. Especially the numbers for 2 & 5. Can someone confirm these are the right steps below?
- Warmed up the car to about 180 on the guage
- by the time I got to starting the test (jacking up, removing wheels etc) it was a good 20 mins. Engine was hot but it wasn't 5 mins wait like Wayne says in the instructions.
- The tool instructions says to remove oil dipstick, coolant fill cap and open throttle body. I did oil dip stick and coolant cap only.
- If I remember correctly, the TDC set is good for cylinder 5 & 6. Need to rotate 360 for cylinder 4 & 3. Once again turn over for 1 & 2. I could be mistaken but if the engine was not at TDC then the air leaked severely and did not hold. So I knew I was not at TDC for that cylinder. Hope that was the procedure.
- Pressurized each cylinder for a min of 5 mins and max 10 mins
- air comp outlet guage was around 75 psi and the air pressure guage on the tool itself was around 25 psi.
Sorry If the information is already somewhere. I just couldn't find it for the Boxster e-gas. What I found were all related to 911. Also Wayne's instructions do not emntion taking out the oil dipstick and the collant cap etc. So am confused about that as well.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
