Old 12-27-2012, 02:57 PM   #2
Topless
Track rat
Topless's Avatar
If it is really stuck, soak it in penetrating oil and let stand overnight. I have had luck by starting the process by turning clockwise just enough to break it loose and then backing it out. Sometimes the bolt is just corrosion-welded to the wheel carrier and nothing will prevent it from stripping out. Then you will need a timesert or fresh wheel carrier.
