A leak down check is a single data point and can often change one day to the next. What was the impetus for doing a leak down test? Is the car using a significant amount of oil? Is it down on power? Oil fouled plugs?
In the aviation industry we do compression and leak down checks annually at a minimum and in many cases every 100hours of tach time. The readings go up and down from check to check but should stay within a certain acceptable range. In aviation, more than 12.5% (70/80) gets a second look as does a variance of more than 7 percentage points. I'd be willing to bet that you could find factory new auto engines that have leak down values in excess of 10% (hopefully not Porsches). I'm sure Jake has his reasons, but his numbers seem a bit conservative to me, but then I've never built a Porsche engine, just aero and motorcycle engines...
If the engine is running reasonably, I'd not tear it down solely based on the numbers you've posted...
