Old 12-24-2012, 10:29 AM   #2
JFP in PA
If you have the silver outside cover, water should not be striking through it. You may still get moisture wicking up from below if it is not pulled tight under the car.
If yours is striking through, it needs to be replaced as trapped and fozen water will ruin the finish long term.
JFP in PA is offline   Reply With Quote
