Old 12-23-2012, 07:36 AM   #3
JFP in PA
Originally Posted by doragman View Post
What is the correct operating temperature for the 986 2.5 ?
.....I can't interpret the lines on the temp gauge very well, but based on the OBD scan tool reading I'm @ 210F after it warms up -- goes to 225F in heavy traffic ...I have NOT cleaned behind the radiators...yet
whatcha think ?
Not uncommon. The OEM thermostat is not open until around 190F or so, and normal coolant temps in the 210F+ range are common. If you could test various areas of the engine with a non contact pyrometer, you would find local "hot spots" that are much higher. Your oil is also even hotter than the coolant by around 15F.
This is why a 160F replacement thermostat is an interesting upgrade.....
