Old 12-22-2012, 12:04 PM   #1
Topless
Track rat
Topless's Avatar
Yes you could just remove the cover and look but it won't tell you much. If I lived in the UK where there was a high probability of moisture intrusion into the bearing, changing it would be a no-brainer. The actual failure rate is guesstimated at between 2-5% of all m96 motors produced so odds are in your favor. Compare the cost of changing the bearing vs the cost of depreciation if you owned a 2009 and it might be easier to swallow.
