I have an '01. The only time that the light comes on is when the top is not fully up or fully down. The latch or the hand brake switches do not trigger the top light.
Do not know if the switch on the motor is a multiple pole switch, but when you raise or lower the top, does the motor automatically stop when the top gets to fully up or fully down position?
If the motor stops on it's own, maybe the "brain" is confused,
. Might just disconnect the battery and reconnect.
