Old 12-21-2012, 07:03 AM   #6
nathan_h
Originally Posted by Vista glass View Post
nathan h
I have a passenger side mirror from a 98 986. The setup was for remote drivers side control, 3 position memory, heated. The motor is fine. The housing(black) has a crack and the glass is broken. PM me if that might help you out. I will send the whole thing. I can disaasemble and check #s and take pics to see if it matches the one you posted.
That sounds very promising.
We don't have the seat position memory, nor the related mirror position memory, on our 986. But I'd guess the motor assembly is the same.... probably.
This is the ring that came off the motor assembly. It is not supposed to do that when you pull off and put on new glass. In trying to see how to secure it, it was apparently that some of the retaining mechanisms were damaged, aged.....
nathan_h is offline   Reply With Quote
