Originally Posted by pecto3
Hi! Drove the boxster this last Friday for approx 100 miles, coolant reservoir showed maybe 5 mm depletion of coolant. Has been a steady loss of 1 or 2 mm from the expansion tank when driving around town. Im sure someone have experienced this, I hope a simple remedy would be a cap replacement or am I due for an expansion tank replacement. TIA.
Pull up your carpet in the back trunk as well as the plywood base and look for coolant puddling up on the metal. If this is the case, then you need to inspect it and see if it's a loose clamp, cracked hose or the expansion tank itself.
Mine was a little low and I put in some distilled water (just a little) and never had a problem since, so it's worth watching and checking out, but not fretting over.
