Old 12-12-2012, 02:18 PM   #1
shadrach74
Originally Posted by Kiritsugu View Post
Actually, we had a check engine light for a vapor leak close to when we got it. Could you elaborate on the Gas cap issue? And we thought, after talking to someone with a similar issue, that it might be a bad chassis ground as well...
Whoa... You need to be specific symptoms. Now that you mention chassis ground it seems as though you're suggesting it's a cranking issue. Does the car crank normally but the engine hesitates to light off smoothly or is it cranking inconsistently?
shadrach74 is offline   Reply With Quote
