Thread: Awful News
Old 12-10-2012, 07:09 AM   #12
boxster6354
boxster6354's Avatar
Originally Posted by Flavor 987S View Post
Sorry this happen to you. But why would you continue to drive? The risks are just too high.
Agree on both points.
A lot cheaper to call for a tow vs. engine replacement.
Also for the other poster, regardless if your car has two or three radiators they still share the same coolant and if you bust a line or crack a tank you will drain the system of coolant, the other(s) will not compensate as a redundant system.
Also with a engine running at 190ish degrees it really does not matter much with outside temp.
Hope nothing was warped as it does not take long with no coolant.
Good Luck!
boxster6354 is offline   Reply With Quote
