I'll be checking everything in an hour. Coreseller, thanks for the info. I've cleaned the radiators before too, so hopefully it will just be a radiator that needs to be replaced. Last night I briefly looked under with a flash light and didn't see anything out of place. When I was driving back, my car pulled to the side so I suspect maybe frame damage, wheels out of alignment, or maybe, if I am lucky, traction loss on the passenger side due to slick coolant. I spun around twice when I made a slow turn because the radiator is right in front of the passenger wheel, and coolant coated the tires.
