Old 12-07-2012, 08:21 AM   #1
particlewave
A test light would be much worse! Much, much worse! Electrons allowed to flow through a conductor freely is not a good idea.
What you need to do is use a diode so that current only flows through the meter and into ground...but I'm not going to elaborate because if you didn't know that already, you shouldn't be poking around with a mm.
