Old 12-07-2012, 05:03 AM   #10
shadrach74
Originally Posted by jovie View Post
Are these test pipes will pass EMISION TEST (smog test)? does it create CEL? Does it sound better or it needs the whole catback exhaust? I just want to make sure I don't encounter minor erritating issues when I purchase and install it.
The emissions issue will depend on how it is tested. If it's a simple OBD plug in test, than passing should be no sweat. If the emissions testing is done with a sniffer, then passing will depend upon state standards. I don't know how much work the secondary catalyst is actually doing, but I would expect to see some increase of unburned hydrocarbons (I doubt it's a significant increase) as a result of removing the secondary cat.
Mid pipes should not cause a CEL as the secondary cats they replace are unmetered.
WRT fitment issues, I would not expect any aftermarket part to fit perfectly without some degree of fettling. Sometimes things fit perfectly, sometimes not so much...
shadrach74 is offline   Reply With Quote
