Originally Posted by Heiko
Thats a big breaker bar for taking off those lugnuts, there is no way that the lugs should be that tight to break the locknut key... WOW... Somebody obviously over did it using that key once before and it was beginning to split.....
130NM or 95.8 ft/lbs is the torque spec although i generally torque mine between 86-88.... never an issue so far with the key.
Actually I use a longer one. I only torque mine to 90lbs. With the long bar it is easy to remove. I hate using impact gun to remove. A few slips is all it takes to mess them up.
