Old 12-06-2012, 02:06 PM   #1
Bala
Originally Posted by Heiko View Post
Thats a big breaker bar for taking off those lugnuts, there is no way that the lugs should be that tight to break the locknut key... WOW... Somebody obviously over did it using that key once before and it was beginning to split.....
130NM or 95.8 ft/lbs is the torque spec although i generally torque mine between 86-88.... never an issue so far with the key.
Actually I use a longer one. I only torque mine to 90lbs. With the long bar it is easy to remove. I hate using impact gun to remove. A few slips is all it takes to mess them up.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
