Old 12-06-2012, 04:47 AM   #10
Homeboy981
Homeboy981
Homeboy981's Avatar
Originally Posted by shadrach74 View Post
I have 2 sets of TS test pipes at home waiting to be installed. The second set is slightly different from the first. I hope to install this weekend. I am hoping that I can make some combination of what I have work properly. I will post pics this weekend and send the unused pipes back to Che.
Hi Shad,
Make sure the ones you put in look like this when you lay them out BEFORE installation. (they are laid out backwards in the photo FYI)
You should be able to do this with ONE SIDE to ensure you have the correct bends…
See how the FLANGE IS DIFFERENT? That IS PROOF POSITIVE you have the CORRECT PAIRS.
Good luck with the install. The best way to not have a problem with fitment is to mount loosely and then, once everything is "in the air" torque it down good and tight. Drive it long enough to warm up and then re-check tightness.
There will be some added sound and low end torque increase but your car will definutely 'breathe easier'. So will you!
Enjoy!
