Old 12-05-2012, 06:45 PM   #1
Heiko
Heiko's Avatar
Thats a big breaker bar for taking off those lugnuts, there is no way that the lugs should be that tight to break the locknut key... WOW... Somebody obviously over did it using that key once before and it was beginning to split.....
130NM or 95.8 ft/lbs is the torque spec although i generally torque mine between 86-88.... never an issue so far with the key.
Previously owned:
