Problem solved...
I took off the driver side fender liner to get a better look at the black tube that attaches to the tower that holds the electrical socket. It is part of the headlight washer system. It clips into the tower about 1/2" to 1" below the top.
To remove it from the tower, simply exert gentle pressure on the tube near the top of the tower toward the center of the car. The tube will slip out of its "U" shaped holder.
If you want a better look before unclipping it, remove the 3 large nuts holding the tray to the fender as well as the nut holding the washer unit to the tray. Slide the tray up over the bolts and forward an inch or two and you have a better chance of seeing how the tube is clipped to the tower.
